Chugging or miss fire
Snowbum
Snowbum
TYF Newbie​
Ok so yesterday out of no where I got a semi rough start, and rough idle. Lots of vibration when I Rev it Maybe not chugging but felt as if not all cylinders were firing. Couldn’t get any codes off of it. I had a fuel filter on hand and that’s why I was/am changing it out. I’m not sure by any means that the filter is the problem.
Due to current fuel prices I have been keeping her filled. That said if it’s the fuel pump, well that going to be a nightmare, but whatever. So my question is has anyone else had this happen? Should I be looking at plugs and wires, maybe CSP ? Or is this a sign that the pump is the problem?
Zero codes
Any info would be appreciated
Snowbum
Snowbum
Info about your rig? Year, miles, flex fuel or not, maintenance history, any codes showing up with a scan tool?
2000 Yukon Denali 160k direct injection weird carburetor thing I don’t think it’s flex fuel , zero codes ,L31 5.7
Snowbum
Snowbum
Snowbum
Snowbum
Had that thought to, but due to gas prices I’ve been keeping it topped off. I use Costco gas which is a very busy station, was also wondering about vacuum lines
S33k3r
Dallas, Texas
I've seen people take something relatively flammable (i.e. carburetor cleaner or the like) and spray around the engine while it is running. If you have an intake leak, that should cause the idle to change in the engine -- though I'm sure I am mangling my description on this one. You might want to search youtube for "rough idle" and get some other ideas.
Snowbum
Snowbum
Yeah I might give that a try
fishcop076
