Check Engine Going On/Off
Eusibius2
Chicago burbs
Did you ever find a solution? What was the result? I had a funky, kinda similar issue. The Mgr for my dealers svc dept told me that all the U codes don't really mean anything, and always pop up all the time and that they're harmless. The P and C codes are concerning though. Like others have said, it could be a bad wire. In my case, it was one of the pins in the connector that was loose.
mckdeezle
mckdeezle
I'm sorry for such a late response but yes the resolution was just a bad connector. Such a simple fix solved everything. So happy it was just that.
I appreciate everyone's expertise on this issue. I am such a space cadet when it comes to cars.
mckdeezle
mckdeezle
Deja vu....‍
The engine light came on AGAIN. More lost communication codes.
The last time they replaced a cable that had bent prongs. Hopefully this is the last time this matter happens
Deja vu....‍
it's going to be the same issue as before bad ground or connection somewhere.
things don't all go bad at once..... particularly when they are completely unrelated to each other.
if it was something like overtemp, hvac turned off, fan malfucntion, reduced engine power, etc those type's of things are all related to one thing.
blackelky
I really hope they work out the kinks i wanted to get a 3.0 after my tahoe dies
Pepper1700
