Can't find brake controller blunt end wires under dash
St. Louis
Tried to install my Tekonsha Prodigy brake controller today. I have this installed on my 2001 that actually has a receptacle on the firewall under the dash to plug into. I want to hook up a harness and bracket into my 2012 so I can just swap it from one vehicle to the other, but I can't find the blunt end wires wrapped up under the dash.
Where does this harness originate from under there, maybe I can trace it down from that location?
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
wjburken
Eastern Iowa
Not sure if this helps but it’s from the 2013 upfitters book.
https://www.gmupfitter.com/publicat/2013_BB/2013_LD_FS_CKTruck_081512.pdf
https://www.etrailer.com/faq-tb-0007-2007-2009-GM-Full-Size-Truck-Brake-Control.aspx
2001 Yukon SLT
Should be coiled and taped to main wire harness under the dash, to the right of your parking brake release and almost under the steering column.
gooffeyguy
St. Louis
I don't have a parking brake release... Lol
I'm just not seeing it anywhere unless it's tucked behind the box with the plug-ins (BCM?)
I'll look again later today
2001 Yukon SLT
2001 Yukon SLT
I figured you did since you did not have RPO JNC, wonder if someone swapped it over like I'm going to do.
gooffeyguy
St. Louis
Interesting.
I doubt the previous owner did anything like that. They were the original owner from an affluent suburb in the area and everything on this looks to have been maintained.
It could've been done by a dealership due to a problem or recall or somerhing like that?
2001 Yukon SLT
Interesting.
2001 Yukon SLT
There were no recalls, it's just easier for some folks to use one version or another. I originally thought it was a model year change and then later learned that it was an option but do not know all there is to know about it. I asked Pete about his 2013 and he has the JNC RPO code.
Did you find the trailer brake wiring?
gooffeyguy
St. Louis
My manual says nothing about pulling a lever to release the parking brake
"To release the parking brake, hold the regular brake pedal down, then push down momentarily on the parking brake pedal until you feel the pedal release. Slowly pull your foot up off the parking brake pedal"
I have not looked again yet for the wires. That video link that @wjburken posted showed that it may be up behind the upfitter box. I plan on checking after eating some lunch
2001 Yukon SLT
wjburken
Eastern Iowa
Found them, they are way up there past that big cylinder that goes to the brake pedal and behind that white connector
Glad to hear it! They really tucked them up and out of the way, didn’t they.
Shunto
Long I$land NY
I know that i am not much help now but i have the same controller in my 4 runner.... worked like a charm! you'll love it! happy trailering.
Drewphil
