Yanked the old stuff off and promptly put it for sale: Its a BMR setup, which has worked good for me.
2 concerns, weight by needing to add the stock transmission crossmember back and ride quality. So lets look at the weight....The BMR torque arm was 25lbs. Then their crossmember was 10 pounds. Making the old setup 35 lbs.
Here's the stock trans crossmember: Its fully boxed and heavy. It should be as the torque arm is mounted to the trans when stock:
The stock trans crossmember:
We are gonna un-box it by cutting the stock welds.
Now this little piece removed might not weigh much:
I mighta hole sawed it too......
TA crossmember cleared my Flowmaster 3 into 4 merge very comfortably.
The Midwest torque arm: about 17lbs.
And this is their crossmember with DS loop:
The conclusion, the BMR setup was 35. The Midwest is 17, I was able to get the TA crossmember down to 5 by eliminating the DS loop, so we are at 22. I was able to get the stock transmission crossmember down to 4 so that's 26. We lost 9 pounds.
Driving impressions: Nice. Quiet, not harsh, I'm really impressed. Traction is about the same on the street. Pinion angle is -2.5.
