Cam swap or mild nitrous shot?
Max
Mile High
Denver
I'll do rod bolts and head studs but an lq4 should hold a 200 shot no problem, question is when will the stock tranny go?
O
odie301
Kasson, MN
Jennabear, how many ponies do you think you gained with that cam swap? did you do anything to the heads to support the cam? (i assume most people put in better valve springs to stop valve float) Different rockers or pushrods?
i read a post somewhere on the internet about how good stock heads flow, so i am less scared of swapping cams...just dont know if you can swap valve springs with the head on or not?
Ok so for this Trailblazer torque converter thing...what is the difference between the trailblazer and my tahoe's stock one? Is it a simple bolt in swap, or do you need more supporting mods? Will this help mileage or anything else for daily driving use?
JennaBear
Resident Ninja
San Diego, CA
When I swapped out the cam, I installed new headers,LS6 springs and pushrods. Shortly after, we installed the blower, 42lb injectors.
tybardy
everyone needs a Hoe
Gilbert Arizona
hey jenna, little off topic, but tell Justin thanks for getting back to me so fast... Black Bear performance just continues to exceed my expectations... you guys RULE
JennaBear
Resident Ninja
San Diego, CA
Eventhough he was busy pampering me today (my birthday) he was also trying to keep up with all his incoming emails! He takes pride in customer service that is for sure!
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
did you milk him for all he is worth (i hope he showered you with the finest diamonds, fed you the finest steak, got you the best masuse available, and polished your tahoe and new mercedes slr miclarin, if not he is a cheap bastard. JK Happy 23rd birthday. Can I be moved to the top now. lol.
tybardy
Gilbert Arizona
well then my thanks ALL go to you today jenna for putting up with Justins other comitments ;) he has a customer for life here
JennaBear
Resident Ninja
San Diego, CA
Nah, I don't play those games :hands:. We went shooting and then hit up TopGolf and dinner. :Handshake:
I have learned to accept that it is just a small part of the business that I have to deal with. :imo:
road1will
pretty pretty good
Johns Creek, Georgia
it's her 28th birthday
Max
Mile High
Denver
it's the same for 4.8, 5.3, 6.0, etc. Depending on the kit you should be able to use it on a number of vehicles. The plate kits are designed for different sized throttle bodies, our trucks use the 78mm which also works on certain f-body ls1 cars.
PexoA78
