Calipers
mmeachem
Do you know the "hub" that connects the wheel to the rim
"brake hub" in the rear and front
Can I sand the rust of then paint it silver with my caliper cleaner and paint
06xl
MD
What will be the purpose you won't be able to see once the rotors are on
mmeachem
mmeachem
Right in front of the rotor behind the wheel face is a rusty hub looking thing should I sand it and paint it
Splatmaster527
Cleveland, OH
If I understand you correctly you are talking about the part of the brake rotor which slips over the wheel hub. If you want it painted go buy new rotors and start from there so you dont have to worry about the just and stuff that arnt very expensive. Or buy high quality one that come powder coated if its a big deal to you.
http://www.r1concepts.com/gmc-yukon4wd-2003-brakes-disc.htm
06xl
MD
Ahhh ok yes I know what your talking about I did that to my rear rotors it's was silver and didn't match the front black Wilwood hat so I sanded it hit it with a wire brush 2 coats of flat black an 2 coats of glossy black about 800miles later still looks new
06xl
MD
mmeachem
mmeachem
Ok so that's what I'll do
What color should I do the calipers and hubby thingys
mmeachem
mmeachem
With a truck this color all suggestions are welcome
mmeachem
mmeachem
What about silver*****
Duplicolor or G2
Or Spray VHT SyStem
(Cleaner-Primer-Paint-Clearcoat)
06xl
MD
Silver will look nice too an g2 works great one can may not be enough for the calipers and rotor hub also while your king that an the rims are off you should paint the wheel wells gloss black gives it a fresh look
mmeachem
mmeachem
Ok will do them silver in a week or so when it stops raining
JeffK
