C0585-1A AND C0590-1A codes - reproducible
LeeGH
North NJ
2018 Yukon Denali, 105K miles
Just had both rear shocks and compressor replaced by our fleet mechanic. At their recommendation, we went with aftermarket shocks (almost $1K price difference!)
It has been about 2 weeks since they were replaced. Problem didn't start until a couple of days after I got the truck back, and on the way to work in the morning, I got the "Service Suspension System" error. Pulled the codes but did not clear them because I was planning to take it back to the mechanic. The codes cleared themselves on the next start, and after talking to the shop, we decided I would take it there next time I got the error. Well, the codes never came back until 5 days ago, and now it occurs practically every morning, but is gone upon the next restart. I plan on taking it there and dropping it off one night so they can reproduce the error, but I am wondering if this is something that has been seen before.
(I also found out that the truck is now limited to 85 MPH when the error is set... :D )
I recommend that you get yourself a quality bi-directional scanner to add to your tool box. Then, you will be able to read ALL trouble codes, along with a brief explanation/pointer to the source of your issue. You will also be able to reset/delete trouble codes, after taking corrective action. You will literally save thousands of dollars in diagnostic and repair costs over the life of your truck, and you will most likely recoup the cost of the scanner within 1 year.
It is particularly helpful in troubleshooting active suspension issues.
MoundMedic7
