Broke line on steering rack
dirtydenali07
2007 Yukon xl Denali. Pulled steering rack out to replace bushings. Ball joint clamp wouldn’t fit over the steel lines on the rack, so I removed them. They have threaded fitting on one end, and a flange and o-ring on the other end. On the longer line, the end from the o-ring groove down broke off inside the hole. I was able to remove the end, but now I need a new line. Can’t find what I need on line. I need this part ASAP as the Denali is the family truckster. Any help is greatly appreciated. Thank you in advance.
conner04
