Brett's 2004 Escalade 6.0 AWD build
adventurenali92
Big Bear Lake, ca
Those tips look cool. Are you just taking the end of your stock pipe off and welding that on? Or are you doing a whole exhaust setup? Been wanting to do something different with my exhaust but a whole set up isn't in the budget right now. Lol and the stock tip on mine isn't terrible but I want a different look.
95escahoe
95escahoe
I'm gonna cut the factory tip off, weld this on and install that Magnaflow Muffler and call it a day, the exhaust is in great shape and it's a hair under 3" no need to redo it all imo
adventurenali92
Big Bear Lake, ca
Oh ok that's cool. I may do the same. Piping under my truck is in fine condition. I'd be curious to see what that magnaflow muffler sounds like. I've heard that some of those cause a lot of drone. Post sounds clips when it's done haha. Where did you get the tip from?
95escahoe
95escahoe
I'm thinking the factory piping is some type of SS piping too not really sure looks too clean imo, this is the biggest 3" dual in and out muffler they make aren't many options unless you want to convert to a single in and out muffler or run two mufflers, I'm hoping the next week or so as soon as I get the new tip, got it here https://m.ebay.com/itm/Exhaust-Tip-...gle-Black-St-/362083468242?txnId=885545774023
adventurenali92
Big Bear Lake, ca
Cool cool. That tip will look awesome on your truck!
Cattivo
The Concrete Jungle
Got the same plate frame as I got for the rear for the front plate, when I get the new front bumper gonna throw this front plate delete on
Come get the Esky front bumper whenever you want brother and anything else you need
Fosscore
Finishes off that front end nicely. Did you paint your radiator supports? From the picture, it looks like it is slightly peeking through or maybe it's just the angle.
95escahoe
95escahoe
I never painted it but someone had in the past, might have to touch it up down the road
05Single
afraid of the dark
Usually I sand and spray flat black paint on all my trucks crossbars behind the grille.
With the tahoe I only washed and sprayed flat black plastidip. Still holding up. Down side is it doesn't reflect the blue led glow I have in my grille but thats ok
DenaliJJ
I put the 12469 on my Denali and yet to have any annoying drone. It's for a deep grumble when low and really screams when laid into it. Curious how the 12599 sounds also I'll try and get a video up one of these days here
veteran111
