I was wondering if there are any other larger rotors we are able to put on our NBS Tahoe? Im not talking about a BBK cause Im not doing that kind of driving for a BBK. Just wanted to know if I can get a larger rotor.
Dan
Dan
Dan
I did the +07 and up brake upgrade on my 01 yukon.
Went with drilled and slotted all around from R1 concepts.com
Best decent price brake upgrade:
1. hyrdroboost swap (junkyard) - $200-250
2. Stainless Steel brake lines (russell brand) - $100
3. GMT 900 front brake swap (calipers w/bracket and new pads/rotors) $300
I do not agree with a larger rotor when the caliper remains the same size so the breaking area only applies to the increased distance on the rotor not more friction surface area on the pads.
New New Body Style
2007-present body style. Front rotors are an inch bigger in diameter and calipers are a bit larger as well. You will need to have at least 17" wheels to clear the NNBS size rotors.
I thinking of doing the same except the +07 rears I heard are actually smaller than the ones you had to start with.. Where did you toyo get you calipers?? Just the local parts store?
Thanks! Is there a write up or how to installation guide or fairly straight bolt on affair?
