Brake upgrade??
loho16
NOVA
I was wondering if there are any other larger rotors we are able to put on our NBS Tahoe? Im not talking about a BBK cause Im not doing that kind of driving for a BBK. Just wanted to know if I can get a larger rotor.
Dan
hoe
Dan
the rotors off the NNBS trucks are 1" bigger upfront and can be swapped to our NBS bodies with a special bracket the dealer sells. do a search you will find more info.
:Handshake:
Robert.K
San Diego, Ca
No special bracket, just the hardware for the nnbs will do. Caliper and bracket.
Sent from my HTC One X using Tapatalk 2
taylorjm
Saginaw, MI
That's correct. You can buy the NNBS caliper and bracket, plus the same model rotor and it all just bolts into place. You do need at least 17" rims to have enough clearance though.
L
loho16
NOVA
ok thanks for the help. I looked up and saw the bear +1 brakes and rotors but people said the bracket relocator broke so I was trying to stay away from that. I will look into the NNBS rotors and calipers. Again, thanks for the help.
Richi5280
oklahoma
I did the +07 and up brake upgrade on my 01 yukon.
Went with drilled and slotted all around from R1 concepts.com
2005SnowKon
Fort Collins, CO
I thinking of doing the same except the +07 rears I heard are actually smaller than the ones you had to start with.. Where did you toyo get you calipers?? Just the local parts store?
DESSKI
Sherman Oaks
I'm also interested in upgrading my front brakes. I'm a newbie so what does NNBS stand for?
mattvand
Iowa
New New Body Style
2007-present body style. Front rotors are an inch bigger in diameter and calipers are a bit larger as well. You will need to have at least 17" wheels to clear the NNBS size rotors.
THE YETI
Director of Operations
South FL
Baer makes a 15" rotor that just uses a caliper bracket to kick the caliper back a bit. They are about $600/set. The make a matching 14" rear rotor as well.
01Konvict
Boats n Hoes
Raleigh/SML
Best decent price brake upgrade:
1. hyrdroboost swap (junkyard) - $200-250
2. Stainless Steel brake lines (russell brand) - $100
3. GMT 900 front brake swap (calipers w/bracket and new pads/rotors) $300
I do not agree with a larger rotor when the caliper remains the same size so the breaking area only applies to the increased distance on the rotor not more friction surface area on the pads.
Cole123456
i have a 2003 Yukon XL 2500....
does the same brake rotor upgrade apply? or does my 3/4 ton have different brakes already?
answered my own question from googling.. it looks like both NBS and NNBS in the 2500 line, have 12.8 inch rotors.
where as NBS has 12 and NNBS has 13 in the 1500 size.
Colossus
I agree with you. BUT big rotors sure do look cool behind big wheels!!
I have a re-maned hydro boost and used master if any one wants it. CHEAP CHEAP
Freedom Motorsports
Whether you are upgrading to the later model larger brakes or staying with the stock size replacements. There is no better value for those on a budget than R1Concepts drilled and slotted rotors and their ceramic pads as a package. I have run them on several larger trucks and never had one issue. This can be said of those that have ordered them through me over the years. Those that have not upgraded the size of their brakes have nothing but good things to say about the upgraded parts performance.
DESSKI
Sherman Oaks
New New Body Style
Thanks! Is there a write up or how to installation guide or fairly straight bolt on affair?
Richi5280
oklahoma
really i never heard about the rear being smaller i told they were the same but i might be wrong. the front ones are 1" bigger. and yes local parts store i got mine at autozone
mattvand
Iowa
Straight bolt on replacements.
Make sure you get the new 2007+ calipers and brackets, your old brackets won't work. Same mounting bolt holes on the knuckle are used, though.
You'll probably also want to pick up a couple new banjo bolts for the brake line attachment to the new calipers, if they don't come with them.
Pachanga02
Ny
I did the nnbs brake swap to mine and am really happy with the braking. On stock wheels (17) it stops I feel a lot faster, with the 24" wheels the braking is also great. For the price and from my experience I would recommend doing this swap.
Buford bubba
