Brake Issue. Stiff Pedal at Stops
Biggwaukegan
Banned
Land of Abe
Guys I got a real annoying issue here. My antilock brake light is been on for awhile. Problem Im having is when I come to a stop it seems like my brakes get all hard and almost cant push the brake pedal down unless I release it and pump it again. I can deal with it but my wife doesnt even want to drive it unless I fix it. Someone has to have had this issue right? Could it be the brake sensor? hub?:wtf2:
bowtiefreak
No Quarter
Near Philly
mine just did something similar but at 10mph or so the antilock would kick in and the pedal got funky. Pulled the main fuse for the ABS under the hood and it's better. I think mine is a front speed sensor.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
It sounds like one or more of your modulator valves is malfunctioning or the controller that actuates them. DTC 41-54 would confirm this if you could get the abs scanned.
Bowtie if I may, yours is probably suffering from the air gap issue which would be a little more sensitive with bigger tires.
---------- Post added at 03:02 PM ---------- Previous post was at 02:05 PM ----------
Actually I wanted to say isolation valves. Sorry.
96ProCompTahoe
IN
pulled the main fuse on mine as well. the ABS wasn't functioning properly with the 35's but the light was not on.
SunlitComet
OBS Jedi-Do Good
The bulletin below talks about abs activation at about 5mph but with larger diameter tires it can be fooled to happen at about 10-15mph. It involved a dirty rusted mount for the sensor. I am sure you have heard of it. Perhaps it effecting your vehicle too. It would not make the light come on. I would think a programmer could help coorect it.
Bulletin No.: 02-05-25-006B
Date: January 05, 2006
TECHNICAL
Subject:
Antilock Brake (ABS) Activation At Low Speeds (Clean Wheel Speed Sensor Mounting Surface)
Models:
1999-2000 Cadillac Escalade
1995-1999 Chevrolet Silverado (Old Style)
1995-2000 Chevrolet Suburban, Tahoe (Old Style)
1995-2003 Chevrolet Astro Van, Blazer, S10
1995-1999 GMC Sierra (Old Style)
1995-2000 GMC Yukon, Yukon XL (Old Style)
1995-2001 GMC Envoy, Jimmy
1995-2003 GMC Safari Van, Sonoma
1995-2001 Oldsmobile Bravada
Supercede:
This bulletin is being revised to update the correction and warranty information. Please discard Corporate Bulletin Number 02-05-25-006A (Section 05 - Brakes).
Condition
Some customers may comment on ABS activation at low speeds, usually below 8 km/h (5 mph). Upon investigation, the technician will find no DTCs set.
Cause
The cause of this condition may be an increased air gap between the wheel speed sensor and the hub reluctor ring due to rust and debris built up on the sensor mounting surface.
Correction
Measure AC voltage and clean wheel speed sensor mounting surfaces.
1. Raise the vehicle on a hoist.
2. Disconnect both the front wheel speed sensor harness connectors.
3. Place a DVM across the terminals of each sensor connector.
4. Rotate the wheel with hand speed and measure the ACmV's. The reading should be at least 350 ACmV's.
5. If the reading is between 200 and 350 ACmV's, remove the wheel, caliper and rotor in order to gain access to the speed sensor.
6. Remove the wheel speed sensor and plug the hole to prevent debris from falling into the hub during service.
7. Clean the wheel speed sensor mounting surface using a wire brush, sand paper, emery cloth, ScotchBrite(TM) or other suitable material. Be sure to thoroughly clean the wheel speed sensor surface. There should be no rust or corrosion.
8. Check the sensor head to determine if it has been warped/distorted due to the corrosion build up or other causes. Check the mounting surface on the sensor head for flatness by placing it on the edge of a metal machinists scale or other suitable straight edge to measure the flatness. Check the sensor for flatness in multiple (minimum 3) positions/directions. If the sensor head is distorted, replace the sensor.
9. Apply (spray) two thin coats of the specified rust penetrating lubricant (corrosion inhibitor) to the complete sensor mounting surface on the bearing hub. Allow to dry for 3-5 minutes between coats. Use ONLY Rust Penetrating Lubricant, P/N 89022217 (Canadian P/N 89022218).
10. When the corrosion inhibitor is dry to the touch (about 10 minutes), apply a thin layer of bearing grease to the hub surface and sensor 0-ring prior to sensor installation. Use ONLY Wheel Bearing Lubricant, P/N 01051344 (Canadian P/N 993037).
11. Install either the original sensor or a new one in the hub and secure the sensor. Ensure that the sensor is seated flush against the hub.
12. Install the rotor, the caliper and the wheel.
13. Place the DVM across the sensor terminals and recheck the voltage while rotating the wheel by hand. The voltage should now read at least 350 ACmV's.
SunlitComet
OBS Jedi-Do Good
Hey Bigg, just note the notice I posted probably would not help you I put that there for Bowtie. But good luck on your inspection.
billy69tahoe
kettering,ohio
i dont know if this helps but mine was doing the same thing and it was my brake booster.changed it out and as good as new!
dizhai
