bottom chrome molding?
22ohdenali
Does anyone know if that long chrome molding on the bottom doors is just stuck on or mounted to the body? I'm considering having it just taken off when getting my chrome delete rather than have it wrapped. Thanks!
R32driver
pretty sure they're held on with clips that go into actual holes in the doors. That's what I've read at least. Its funny they only put them on the higher end trims but these vehicles look much better without them
WalleyeMikeIII
Sunny and Snowy Minnesota
I asked that question of my previous model (2013 Suburban LTZ, and was told it was just adhesive).
This seems to make more sense to me, as if it is held on w/ clips, there are 2 issues:
1) Hole in the body is an invitation to rust
2) If they put holes in, then they have 2 different door part numbers to manage.
My guess is it is just stuck on there...best way would be ask your dealer, they may find a parts diagram or could look and see if the door part number is the same between the upper and lower trim levels.
R32driver
Idolan
Just wrap in white vinyl like I did and it disappears
Okiedave
Oklahoma City
Timely question. Mine are starting to curl away from the body. Yesterday the small one between the rear door and rear tire on my XL came off as I was washing it. That small one is just adhesive on my 2001. I am thining of pulling the rest off if they are all just stuck on, which is all I can see from the ones that are curling.
TiGrayMSM
