Bose Premium Amp wont turn back on.
indigoblue2001
scs,mi
so i was so happy today. got my gm interface so that i can install my aftermarket kenwood radio... got it all installed. no sound. dumb founded for about 20mins. checked over all the wiring then thought check the fuse. take off the cover there was no fuse in the fuse spot. check owners manual and it doesnt say what size so i put a 30 amp in.. now i have sound. was soooo happy. UNTILL i turn off the truck and turn it back on... NO SOUND... so im like what the hell. PULL FUSE and put it back in guess what I have sound again. SO WHATS THE EFIN PROBLEM why is it the amp wont turn back on after the suv is shut off. all the wiring matches up so i know thats not an issue. PLEASE HELP I NEED A RADIO..
RRWW
What harness did you use?
Do you have a good connection the blue with white stripe (I think) remote turn on wire?
If you have it connected do you have a multimeter to check to make sure it has output to the Bose amp?
I
indigoblue2001
scs,mi
AX-GMCL2-SWC
GM Data Interface with SWC 2000-2013. is what i got. and yea its the blue wire with white stripe is the amp turn on. it got real cold so ill have to mess with it friday after work.
I
indigoblue2001
scs,mi
Um hello I could really use some help here. i mean isnt this what this forum is suppose to be used for.
at any rate,
have you double checked your wiring connections?
why was the fuse out of the bose amp? previous issue's?
did you contact axxess tech support yet?
it's not like someone is standing over your shoulder, we need more details
I
indigoblue2001
scs,mi
at any rate,
its not like im asking someone to stand over my shoulders. id punch them in the face if they was. now yes i checked all the wires.. yes i called.. and i dont know why the fuse amp was not there i bought the suv used. so i dont know if there was issues before. it didnt come with a radio bc the idiot before me removed the factory radio and didnt put one in. and no i dont know why he did that. so i know the amp works if you remove the fuse and put it back in. what else would you like to know.
RRWW
Did you ever probe the blue white with a meter to see if you have a turn on signal to the amp?
Just because a connection is made we can't see electricity.
Has the factory Bose plug been modified? Test grounds to amp?
How did you connect the radio wires the the module? Crimps? Solder? Wire nuts?
Without much info and not being there to see what's been done we are all just guessing. Getting in a tiffy isn't gonna help solve your problem. You need to provide some data.
Good luck
Rcarew907
