Bilstein 6112 Lift Amount
Carp0331
2009 Avalanche LT 4x4. I picked up a set of Bilstein 6112 for a 07-13 Silverado. Settings are 1.85-2.75” depending on which notch. With 33” tires after I installed the passenger side at lowest notch it was sitting at 42” to the fender. Stock is around 36” on stock tires. So with that 33’s this is almost a 5” lift. I didn’t do the driver side. Went back to stock tires and stock struts.
Anyone run these on their suv or the 0-1.85 6112’s? Drive side stock is .5” lower. I was planning to run the bilstein on lowest with a .5” spacer on driver to level it out.
BadDaddy2003
