Belts squeaking?
Slopples
In the morning when I start up and drive for the first hour or so my Yukon has a terrible squeaking from the front. Sounds like the belts. But after that hour it goes away and doesn't come back until it has sat for several hours, usually over night. I have an 04 Yukon SLT. I don't want to go replacing things that dont need to be replaced but I can't figure out whats causing it.
ScottL4619
Columbus, OH
Maybe the belts only squeak when they are relatively cold. And once they warm up the noise goes away. You have an 04 with Efans, it's super easy and not very expensive to change the belts out and see if the noise goes away. If it does not, it could be either tensioner or the idler pulley.
blueflamed03
Oklahoma
belt, or tensioner like mentioned...if the belts squeaking, replace. All you need is for it to snap at the wrong time.
DenaliAK
Colder than you
Alaska
Happens all the time up here, the dreaded squeal. For some reason, probably because the belt is cooler and stiffer, it's worse right after startup.
90% of the time all you need to do is tighten the belts. Try that first...it's free.
BubZX
Senior Member
Waynesboro PA
had the same problem on my hoe. inspected the belt to make sure there was no cracks or weak lookin spot s then started it up and sprayed with belt dressing. no more belt squeak :)
S
Slopples
Well I finally had time to single out and it is the pulley. Its a little loose. I have no idea how to tighten it and the internet has left me at a loss. I'm just going to go out and figure it out, it can't be that hard.
DenaliAK
Colder than you
Alaska
I haven't actually done it on one of these, just my car. It usually involves some muscle, leverage, and someone else to tighten things down....lol.
slicksdude
Like one of the dudes mention'd above.. Check for cracks or weak spots, mean while you could spray some belt dressing il remove the noise instantly! Workd for my Hoe!
ScottL4619
Columbus, OH
Just replace the idler pulley and be done with it. Since the belts are relatively cheap, just replace them while you're at it.
The only way to tighten the belts would be to put more tension on them. Since the tensioners accomplish this, new ones with tighter springs would be your only option.
I replaced both tensioners and belts for $75ish in less than 45 minutes.
JonTouma
Puyallup, WA
Belts Squeeking
Does anyone know where I can find the instructions for replacing the belts and pulley on my 2001 5.3l Tahoe...I bought all the parts but I havent found instructions on how to do it online.
bottomline2000
Dallas, TX
waxworkz
its not hard, you have a belt diagram on the fan cover for the belts, for the pulley just get a wrench that fits and take the nut off. i have done both belts and both pulleys and i still have an annoying ******* squeak! i cant pin it down, seems to go away after the truck warms up
JonTouma
Puyallup, WA
Great dude....I have the same problem and havent changed a thing yet...I have heard anything from power steering to tensioner to alternator...I have no clue why it stops after a few minutes....it cant be normal but then again thats what I thought about that clicking noise when I first start it up in the morning.
---------- Post added at 08:33 AM ---------- Previous post was at 08:32 AM ----------
Thanks for the video man...
waxworkz
i'm thinking of doing the main tensioner on the main belt. i believe these are spring loaded and would make sense that spring inside tightens up after the truck and engine bay are warm. that is if the spring tension works like that of a wound spring expanding after it warms up??
mfinta
