Battery gauge riding at almost 19v
PNWYukon
Olympia, WA
The battery gauge has always been at 14 or a tick past, and suddenly today it is near redline, stayed there then, dropped a bit to say 16 or so. Any thoughts?
Otherwise nothing else is crazy and everything works fine.
Does that year have RVC (Regulated Voltage Control)? I think it does, and if so, for some reason the computer thought it wise to crank up the output of the alternator to keep your system running and charged up.
PNWYukon
PNWYukon
Olympia, WA
Started it this morning after reseating the harnesses and it went back to 14.2 voltage with no variation. Battery tested at 14.5 and alternator at 14.7 while idling.
Hope we don't have a gremlin in there somewhere?!
GMT800 2005 Tahoe Z71
Navy Supporting Member
That gremlin may be a voltage regulator starting to have problems or a diode causing problems. Typically when a diode goes you also get a battery drain when shut off. Keep an eye on it.
PNWYukon
PNWYukon
Olympia, WA
After going in circles, it looks like it is officially called the Generator Battery Control Module by GM. We will see. The battery is not a year old, so will do some testing after it has been sitting to check resting voltage.
PNWYukon
PNWYukon
Olympia, WA
Resting battery voltage is right at 12.73v according to the Fluke 77. Have not had another gauge spike since replugging the harnesses.
Hope it stays that way but you know how intermittent problems can be. Maybe just the act of unplugging reseated something better. That is a WAG.
PNWYukon
PNWYukon
Olympia, WA
Still no change from a steady state. Pretty odd, but has not moved a stitch from normal since reseating the connectors. Anomaly? Who knows.
Maybe a good practice is whenever you are messing around under the hood or dash, to reseat any harness/connector plugs? People swear by products like Deoxit also.
scottd
