Banks iDash parameters for the LM2
972sparky
I have installed a Banks iDash 1.8 guage with the latest 1.23v software. I was really wanting to see the emission system info such as soot load, regen status, last regen etc. as well as oil pressure, boost pressure. They do not appear in the selection list on the guage, they do appear in the list Banks sent me of the parameters I should be able to get. Anyone using the iDash able to see these parameters? Want to know if someone else has these working before I spend hours on the phone with the Banks techs.
972sparky
972sparky
I have that part down on setting up your pages and items on each page. It is the actual parameters I want to see that do not seem to show up in the selection menus for the LM2. I can get oil temp but not oil pressure, no boost pressure no regen info. These do not even show up to be selected for display in the menus. Banks sent me a list of what I should be able to get and I am not able to get half of them (they don't show up in the menus). No one else using a Banks iDash on their LM2 Tahoe/Yukon?
TXmango
I am about to buy one. Can you see what gear the trans is in?
972sparky
972sparky
Yes I have the gear readout, I have one CAT temp as well and have been watching that to see if I am in REGEN. I have engine oil temp but not pressure, trans temp but that is available on the DIC, engine and 2 other coolant temps. Has HP and Torque calcs as well. Banks sent me a chart of what I should get but it was a list for the 1500 truck 3.0 and I cant get many of the ones listed that I would like to.
Interesting note on the gear, does not go into 10th gear until above 63mph.
TXmango
Thanks let you know what readouts i get
SeaWolf65
I'm also have exact same concerns on the IDash super gauge (with v1.23 software) readings for my LM2. I can't get many of the ones listed in PID list for new LM2 that I've got from Banks. Are any updates on a solution for the IDash readings?
StephenPT
St. Helens, OR
It looks like a few weeks ago Banks released 1.24 software, which specifically says in the release notes that it added support for the LM2 SUVs.
972sparky
972sparky
Great news! I have been checking every few weeks and had heard of a Beta version for us but couldn't get one. Going to try it out tomorrow for sure! Thanks for the update!
StephenPT
St. Helens, OR
Let us know how it goes. I would like to add one of these, especially when we start towing a camping trailer.
972sparky
972sparky
Here is a link to the idash parameter list for the LM2 in the GMC Sierra 1500. The parameters are mostly the same for the 2022 Tahoe/Yukon. I will list the ones that are not in the new v1.24 update as well as a few others available that are not on the list.
All the air density parameters are available
All the diagnostics are available except TIME, time data log
All the emissions are available except DPF SL, DPF soot load percent (there is a dpfdp1 DPF delta pressure in the pressure list that is the same data I suspect, just not converted to %), LSTRGN distance since last regen.
All the engine performance air are available except THRT-R throttle position relative.
All the engine performance fuel except none of the injector balance rates. There is also a FUEL TEMP not listed that is available.
I don’t have a pedal monster but i suspect if you do they are all available.
All the pressure except OIL P engine oil pressure, TRAN-2 and TRAN-3 are available. There is also a clutch pressure available.
(I am disappointed the oil pressure isn’t available, the factory dash gauge is quite vague and looks quite low most of the time)
All the speed and velocity are available.
All the temperature are available and include cylinder head temp, exhaust gas temp 1, exhaust gas temp 2 and exhaust gas temp 3.
All transmission are available except 4WD-S transfer case status and TR SLP transmission slip. There is a torque converter slip available.
All vehicle performance and voltage are available.
I am making some new pages and haven’t tested all the parameters for relevant readouts yet, but will post update if any don’t seem to work.
If the link to the list doesn’t work, go to the banks web site and then the idash/monster gauge page and locate the 2021 GMC Sierra 1500 3.0L parameters page.
StephenPT
St. Helens, OR
Wow - nice investigation!
It’s interesting that the ‘21 LM2 in the 1/2 ton is able to provide more information than what you can get on a ‘21+ SUV. There must be a difference in the ECM. I wonder if the ‘23 w/ LZ0 is missing some parameters?
The development cycles of the pickup and SUV are slightly staggered so it makes sense that some of the ECMs and software could be different.
As far as the oil pump pressure, I’ve noticed it seems to be pretty low, but as I understand, it’s a variable displacement pump to minimize pumping losses, so it’s only going to pump what the engine needs.
kerlyb
Make sure you have the correct vehicle/motor selected under settings. Go to settings...vehicle...and select LM2 20-21'.
Now you should have everything listed in the PID list.
StephenPT
St. Helens, OR
Those of you that are running a Banks I-Dash, which vehicle profile have you selected? I see there's '20-'21 LM2 (Truck) and also DMax LM2 at the bottom of the list. I just installed my Banks IDash and I'm on software version 1.24. I first selected the DMax LM2 config and when it starts up it shows the DPF regen %, but then after about a minute it goes to "--" on the display and then never shows a value again, even after driving for 45min. Just this morning I thought about trying the other config and selected '20-'21 LM2 and now the DPF regen % stays there, but now I can no longer see transmission temp or gear indicator? Seems like the software is not yet refined for the SUV platform...
I might give Banks a call tomorrow and see if they have a new software version coming soon - the last update was in Dec. of '22. (version 1.24)
972sparky
972sparky
I am using the Dmax LM2 setting and I do have the dpf% and the gear display. I also can get the trans temp but don’t have it selected as I can get it on the DIC. There is a v1.24.7 software out but not on the banks site. Someone has a link to it elsewhere, I’ll see if I can find it again. Did not seem to give me anything new. Still no oil pressure.
972sparky
972sparky
StephenPT
St. Helens, OR
Thank you! I agree, the trans temp is available on the DIC and might as well just show it there - I wanted to run it for awhile on the IDash and see if they both showed the same value and they usually do, with occasionally 1-2 degrees difference. Probably just a refresh rate discrepancy.
I will do a backup of my current setup and then try out the firmware update. I found the thread on the Duramax forum and it looks like a Banks employee was mentioning in that thread they have noticed some instability in transmission and emission PIDs. I'll give this beta update a try and see if it makes things more stable for me as I believe I should be getting the most info out of the "DMAX LM2" config, but losing the DPF RG% about a minute after startup is bothersome.
Steve Smith
What are you guys seeing for fuel rail pressure? Mine varies from 3500 (idle)-29,000 psi
StephenPT
St. Helens, OR
I'm seeing in the ~5K psi range at idle and up to 29K under high load/high rpm. It sure bounces around a lot. I'd say it's at about 17K when doing 60mph down a highway, but any change in engine load due to grade makes the value jump up or down quickly.
Tupapi
