GangstaCowboy
- Joined
- Sep 24, 2011
- Posts
- 137
- Reaction score
- 1
Hello-
Over the last few months I have been trying to track down some vibrations and sound in the engine bay. Currently the symptoms are when idling cold and in reverse the engines will shake making noise in the cabin. The shaking also occurs when the heat or ac is on, regardless of fan speed. Sometimes if I press the brake peddle hard enough the engine rpm will drop extremely low almost like it wants to stall. One occasion the engine died on me while I was parked, but never happened since. I initially thought a TB cleaning would help and it seemed too a little. If revved the car up in park and took my foot off the gas the idle would dip and all the lights would dim for a second and then it would come back up to normal. After the TB cleaning this went away but the other symptoms remain. Has 139k miles on it and new plugs and wires since 110K. Could the TB assembly be bad and the extra load on the engine from the AC system, brakes, or transmission be causing this? Other than this the car drives perfect but I can tell something is going on. One small note when I cleaned the TB the butterfly valve some to stick a little when almost closed. Is that normal?
