Back up camera/nav system on 07 LTZ without one
Slow5.0
Missouri
I have 07 LTZ that dont have back up camera and nav system from the factory. From the factory i have CD/DVD/MP3 with Bose audio system, i think its called opt UVA. Is it passible to install those parts. Did LTZs come pre wired or do i have to do wiring. What full list of parts im gonna need. Also how much money i maybe spending. Thanks
Slow5.0
Slow5.0
Missouri
Yeah but there is way too much stuff writen. I thought Obama Motors pre wire these LTZs just in case someone wanted Nav or backup camera
fiatdale
Houstons Best
Houston
No, not pre-wired. And dont be a dick, besides that, Bush approved the GM bailout. The ******* in office now had nothing to do with it.
If you want a factory setup, buy a used radio. Youll need the brown plug which ties into speed sensor and has backup cam inputs. As far as a camera, there are tons out there that look factory and just require running wires from the lift gate to the dash.
Slow5.0
Slow5.0
Missouri
I know but we like to call it that way, its same thing like Obama phone but it was Clinton who approve them.
Back to the topic
When youbsay radio do you mean one with Nav right. Lets say if i go to local salvage, get cqmera, wires from lift gat3 to the dashboard, nav. I think i read somewhere camera module and sat antena ?
fiatdale
Houstons Best
Houston
You can do all that. But to make life easier, and just as good, get an aftermarket camera, mount it under your applique just like the factory one, and run the wires. Its not worth pulling the harness because it ties into the whole liftgate harness. You can use a factory camera without a camera module, you just need the pinouts, which I have.
For the nav unit itself, you'll need the brown plug (again, which I have) and the GPS antenna. It will then need to be programmed at the dealer to unlock the VIN. Keep in mind - yours is a 2007. In 2010 they added USB, and in 2012 they upgraded to a hard drive for navigation and music storage. 2007-2009 can easily be unlocked at the dealer. Most dealers have a very hard time unlocking a 2010+ USB radio for 2007-2009 trucks, and it requires special programming. Greg at CPS Audio can do it for you for a small fee (and shipping to/from). Hes done several for me and other members on here.
If you go 2012 radio upgrade, the complete radio harness is different, as is the usb connector and XM antenna connector. Harness kits are available though.
Or you can go aftermarket with a unit, dash kit, harness, possibly save some money, and have close to the same features if not a bit more. It just wont look factory.
Hope this helps.
Slow5.0
Slow5.0
Missouri
Would you sell any of those parts that ill need. Im not too crazy about aftermarket unit, so oem will do just fine. I havent check out new audio stuff in last 6 years since i quit messing with cars but now im slowly going to do same dang it
fiatdale
Houstons Best
Houston
I only have the brown plug / pigtail. Theres a chance I may have an antenna laying around, Ill look this weekend. PM me when youre ready to do it.
varminpoolteam
