AWD reliability ? How much power can they handle ?
Outside the ATL
I'm looking to purchase a 2012 Yukon Denali with a 6.2, AWD and 122k miles. My knowledge of the GM AWD system is, well I don't know anything about it. I know Subaru's and Audi's for example can handle there fair share of power and abuse.
So I was curious what the GM could handle. Could it handle something like a Whipple and all that accompanies something like a supercharger ? Are the AWD components upgradable?
I plan on researching more tonight, (will post what I find if the info is already posted) but this is short notice, my wife just found it and we are going to look at it tomorrow when I get home from work.
Thanks in advance.
that's a good year I have the same truck, the AWD system seems pretty good I haven't broke mine yet, when and if the rear diff goes out I will replace the g80 with a eaton detroit, I believe eaton also makes some better internals for the front diff as well, transmission of course can be upgraded if needed from what I have been told the 6l80e torque converters can sometimes fail and then it takes the pump with it but other than that I haven't heard anything bad about them and any concern about the torque converter can of course be addressed as desired. another member on here has his awd all built up and runs it on the track from time to time but can't think of the name at the moment.
67RS427
Thanks in advance.
Transmission and/or rear/front differentials will certain go before the transfer case... I can confirm, 2007 Yukon Denali AWD (BW4485 T Case) running over 850hp here. I beat the crap out of mine and not worried one bit. When I hit 157k miles or so I replaced the original G80 unit with a Detroit/Eaton TruTrac. I also rebuilt my front diff with better bearings but used original ring and pinion front and rear. No need to worry about the T Case, it's got planetary gears and a chain inside, not much to break, just a chain to stretch over time. Unless you launch with my kinda power on slicks you won't need to worry about it.
Hi Mike, there are guys on here putting over 500 horsepower through those systems and haven't broken them yet.
Talk to these guys: @67RS427 @randeez
As I said, I beat the crap out of mine lol... 17"-18" lightweight wheels and drag radials and I might start to worry but I'm not there yet. Soon maybe on my quest to mid 10 second 1/4 miles.
cntryislandboy
Outside the ATL
Thanks for the info guys, it's greatly appreciated. I've never really considered the Yukon before, but thanks to my wife and a few minutes on youtube it's being to grow on me. Seems more luxurious than Tahoe but not quite an Escalade. And I really like the AWD concept.
@67RS427 I'm beginning to read your build thread now.
Chrismnj
NJ
lots of good info there.
the AWD is awesome especially on corners, lol and I wont mention the road signs... haahaa
Baddawg
Vail, Colorado
Okay, so I'm hearing the AWD BW4485 T Case can handle some power. What about the 4WD case in my 2013 Tahoe, the one with 2WD-AWD-N-4WD Hi - 4WD Lo. How sturdy of a unit do I have there?
Chrismnj
NJ
So far we have learned that street signs are tougher, but from what I read once you start messing with power is like a chain reaction sooner or later T case would need some work.
The Magna Power transfer cases are also used by Jeep and Dodge and the off road crowd puts some serious power through them too. They are not as highly regarded as the manually shifted cases of yesteryear but I reckon that is because they haven't been around long enough yet. 4LO does impose a speed limit of 45 mph that I believe the older GMT-800s with their Borg Warner cases did not have. Not sure what that means though. We don't read about too many needing service/rebuilds on the truck forums.
randeez
south florida
saw someone chew up awd tcase planetary gear on pt.net, but i think it was more from offroading. its essentially an open diff design, there isnt much to break in it the side with less load is going to spin. it has its downsides but trans will go long before transfer case will.
91RS
GA
The transfer case is fine, its the front differential that is the only thing to worry about. The biggest problem is that they hold so little fluid and people are so against taking care of their things any more, they get low on fluid over time and eventually it smokes the bearings. Usually new bearings can be put in and everything else is good if they've haven't ignored the noise and kept driving. The lesser problem is there is a tab that holds the bearing adjusters in place and they sometimes break and the adjusters can unscrew and also smoke the bearings. This can be caught early if the fluid is changed regularly. Personally, I don't want one with AWD but I wouldn't pass on a truck that is otherwise what I want just because it was AWD.
BadDaddy2003
