Autoride Failed?...
SilverSport
2005 GMC Yukon Denali with Z55 Autoride...
rear of the truck seems like it is higher than it usually is but ride not too bad...
I no longer hear the compressor when starting the vehicle (several weeks now)
I see some tears in the fabric covering over the "airbag" portion of the shock absorber
my BlueDriver scanner shows nothing (I am sure I need a more comprehensive scan)
I have no dash lights or anything showing issues with the Autoride system
I have checked the 3 fuses underwood to see if it might just be a fuse and they all appear fine
anything further I can look into before it goes to my trusted garage for that comprehensive scan?
If it comes to it, seems that Dorman is who I want for a compressor and possibly Arnott for OEM type shocks or should I just pull it and replace with Bilstein shocks F/R with new springs in the rear?
Any help would be appreciated...I've red many threads here and elsewhere but don't have all the answers for doing this in 2025
Thanks for any help and experience you care to share...
Bill
Bill
pictures of the rear shocks?
generally speaking blown out shocks and a fried air pump will not throw a code
SilverSport
SilverSport
I can't get the pics yet but the Driver's side rear shock had 3 less than half inch "tears" in that outer fabric material
thanks for the confirmation info on a lack of code showing
Bill
SilverSport
SilverSport
and I should add - original shocks and 82,000 miles on the Denali with 2024 GMC Denali 20" wheels and tires...
Bill
If the shock bladders are torn, the shocks need to be replaced. Go to RockAuto.com or GMPartsDirect.com, enter your truck's VIN and select replacement Z55 shocks in accordance with your 3 related RPO codes in your glove box. Z55 6** 7** The cost of the shocks will be around $360 each, and they are now warranted for life. You can also purchase a replacement compressor (OEM or Dorman), as it is highly likely that your compressor has failed as well. This will be significantly cheaper than purchasing from your local dealer.
One part of your description seems odd, though. You say that the rear of the truck looks higher now. Typically, when the rear shock bladders rupture, the truck generally sits a bit lower, as the air in the shocks also supports the weight of the truck in the rear.
dwkehoss
Conn
Bill
2016 Tahoe 70k miles, I had to replace my rear air shocks myself last year. The pump would cycle continuously. One of the shocks had a tear in its boot.
SilverSport
SilverSport
that is my thought as well...but the rear is at least as high as it was prior...no compressor activity...
tears near the bottom the my attached photo - you'll need to open to see the full pic see below
The 08 Tahoe LTZ that I just replaced the rear shocks on also sat high in the rear with obviously blown bladders on the rear shocks which seemed strange to me. I ended up with Arnott shocks and a Dorman compressor. All is fine now. Sometimes this will throw a code on the dash and sometimes it takes a bidirectional scan tool to see the codes.
SilverSport
SilverSport
placed here...pic of driver's side rear shock...you have to open the jpeg to see the tears...
Bill
Juamgv
