Audiovox HR7DDPKG: headrest connector M1 <help needed>
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I got em cheap ($200), but it has 3 broken wires in the connector immediately behind the M1 headrest monitor...
I'm hoping someone here has a set and can look behind M1 and tell me the wire order on the headrest side of the connector.
I need to know which goes where (and no, they don't match on the other side of the connector, nor is the other headrest a match)
I have thin white, thin blue, thin grey loose.
Audio is ok on IR headsets from the M1 monitor now, so this should cure my audio out problem since white should be the missing side (when i figure out where it goes!). It will probably resolve the audio issues when sharing video form m2 to m1 also.
Eagle
Eagle
EL PASO, TX
sorry to bump this but still hoping for a response
Rivieraracing
I wish I could help you man, I even did some searching on the web and didn't even find much of anything helpful except this site!! I don't know anything about this site, so not sure if its legit or not but if it is it looks like you can download some manuals!! Like I said, use it with caution:
http://www.retrevo.com/samples/Audiovox-Car-Video-manuals.html
Also, could try to call up Audiovox and see if they can help you (doubt they can though, there website is useless!)!! Good luck and nice to see you back on here!!
moto
