I’m in the process of upgrading my sound system and have been looking at my amplifier power run and amplifier mounting location.
My current plan is to run a fused 1/0 wire from the battery, alongside the loom that runs from the fuse box to under the truck on the drivers’ side and then ********* into the space under the rear passenger seats for amp power. I know some have run their power wires through the firewall and along the door sills, but I like the “under and in” method for my system.
* For those who have taken “under the truck” approach, is that what you did?
I know this is a subjective question, because many have taken different approaches to this same problem.
* Is under the rear passenger seat the most common (or best) location to mount audio amplifiers?
If not, what other locations are good?
* Does anyone have cool bracket ideas to mount the amps or is a wood board/structure the way to go? (I've seen this on many threads)
If it helps, I’m mounting 2 amps, one for my door speakers and one for my sub.
* When you make the runs from the HU to the amps and from the amps to the speakers, I assume these are run in the door sills?
I will really appreciate you audio guys and those with aftermarket amps chiming in on this one, I could use the direction.
Thanks, Joe
Thanks, Joe
