AT4 3D Printed Items Thread
Fast_AT4
RWM +1
SW Florida
Designed it more so for the AT and 4 letters/number aspect for future projects, but figured I'd quickly do a keychain. Will be 3d printing tonight (will post the final printed version); shell in black, 4 in red, and AT in white. :)
P.S Always welcome to feedback and/or other item ideas :evillol:
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Little AT4 wall decor. Can add 3M tape or even magnets to mount to metal places.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Those are quite impressive.
Etsy? Just sayin...
Awaiting on arrival of AT4 tomorrow mid-day...then I get to design other practical items. Naw, I have my own Domain for about 7years ;). Reached out to become a Vendor, but no such reply thus far. Still waiting on my Membership to be applied as well.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
Rubber tray removed from arm rest for wifi charging aspect
Fender grills coming off this weekend for either full replacement or insert replacement.
WalleyeMikeIII
Sunny and Snowy Minnesota
Some dividers or a tray or something for the center console...the sliding one!
A plastic cradle molded to the shape of a hitch ball mount, that fits in the back under the floor, and keeps the ball mount from sliding around.
A tray that fits in the wireless charger bin, so "stuff" can be easily removed to charge a phone
Building on that idea, that has "legs" on each end, so a phone can sit under it and charge, and you can still have a bin of stuff in there.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
I dont have the sliding center console...so this might need a bit of assistance to design/test something.
Share some pics of your ball mount. Haven't done much towing in my life...but now plan to :)
Good idea. The USB ports and cigarette lighter will also be considered in the design so not to hinder the use.
WalleyeMikeIII
Here’s some pics of the sliding center console
WalleyeMikeIII
Here’s a pic of the Denali Cupholders and Wireless Charging Area. Note much different than the AT4 and SLT/SLE/Chevys
WalleyeMikeIII
Here’s my Ball Mount. Maybe can find actual dimensions on Curt’s web site, or I can measure it
Fast_AT4
Fast_AT4
RWM +1
SW Florida
V4 now printing..trying to get as perfect as possible. Went with this charger due to Magnet for iPhone users.
WalleyeMikeIII
That looks pretty good. I’ve given up on the armrest charger possibility, as the hole isn’t wide enough for an iPhone 13 Pro Max in a case.
I’m going to do an attempt to sketch what I was thinking for the wireless charger bin. I have no CAD skills. Think something like a fully enclosed baby crib with legs on each end, so the phone goes on the wireless mat, this “baby crib” goes over the phone and is supported on the ends by legs slightly longer than the phone thickness. See sketch.
ProfeZZor X
High Country
GM really didn't think things through when they made the center console safe. It's just an open box with no dividing compartments, whatsoever. And the sliding tray has to be removed each time I access the safe, because you can't lift open the safe door without hitting it on the tray. If someone (wink-wink) made a 3 or 4 way divider that fits inside the safe (1 divider for coins), it would eliminate the need for that top sliding tray.
Fast_AT4
Fast_AT4
RWM +1
SW Florida
I think this may be the final version of the Arm Rest Charger. While other solutions include a harness...I took the simple route. Reason being...its simpler and: no need to remove only but 1 panel to tuck USB cable. Made one existing hole slightly bigger (will post pic) to route the USB cable. Since there is so many USB/USB C ports...why not just use an existing. For me, this is perfect. Since the cable is longer enough, will be tapped/attached in some fashion to the wall vs all wild like that as shown. Will be adding a pic showing the over all length x width of "dock able" area. Thoughts welcome :)
WalleyeMikeIII
That looks awesome!!!
dizhai
