Anyone coolant gauge ever do this? Am I being picky?
the 18th letter
Northern New Jersey
Something doesn't seem right there, or you have an aftermarket thermostat with a much lower temperature installed. Or if you haven't done any work at all - have you removed the thermostat housing from the water pump to inspect it? I would be interested to see a scan tool's reading of this temperature. By the ((inaccurate)) gauge alone it looks to be pointing to around ~185. I bet it's lower than that.
Looks like I'll be inspecting the thermostat, mostly likely changing it along with coolant temperature sensor. Fans kicked on high and I lost temprature reading on my way home on a 2hr drive last night. Started the same way this morning but about 10 minutes into a drive around town the fans shut down and temp guage started working. No codes, loss of or low coolant during the time.
BlaineBug
Clown World
Try replacing your coolant temperature sensor FIRST due to your symptoms, and be sure to use OEM parts only!
the 18th letter
Northern New Jersey
I figure they're all 100k parts and I'm not original owner and I just hit 100k. Being that the thermostat was already suspect due to the readings it's worth the 50 bucks. I'll do a coolant change as well since I dont know if it's ever been done.
lilredx
