Any center consoles with a 4x4 floor shifter?
95BlackTahoe
Edinburg, PA
Ok, She's in, and looks pretty good. I am happy with it.
A teaser...
Console Install
Shawn
blue99tahoe24
bout that tahoe life
joliet il
Dude thats looks so sick looks factory how did u do the blue leds
Sent from my PantechP9060 using Tapatalk 2
95BlackTahoe
Edinburg, PA
Now comes the fun part...cleanup...lol...and I am going to make a few slight changes to the shifter cover and the shifter rod...Minor, and really not needed, just doing it for my taste. Overall, it came out good. I have the sub in, and I tested it on my sons Sierra aftermarket amp, and it worked, so I will complete that when i locate my connectors...ugh...
Shawn
95escahoe
Shawn
I like how it came out, you have a link to the write up you were gonna do?
qukon 95
i caame this close to take out a grey console out of a expedition $15.00 i decided it wouid be alot of work to make it fit. i need to look for a escalade console.
qukon 95
i'm going back to the jnk yrd in the morning to get my 99 esca console $10.00 $ 15.00 with the bose sub &amp the back lower
cup holder door hinge is broke. has any body tried bending the 4 x 4
shifter?
qukon 95
95 black tahoe did you do any trimming on th 4x4 gear shift cover?
i got the console ,shift cover,the bose set up in it, the rear controls,
the wiring im going to take it apart to night
95BlackTahoe
Edinburg, PA
Yeah, it needed to be trimmed on the top side and the bottom as well.
Console Install
The above link may help in case you hadn't seen it yet...
Shawn
---------- Post added at 10:21 PM ---------- Previous post was at 10:18 PM ----------
I forgot to mention, in the one picture of the shift rod, it appears to be a little bent to the bottom...so to speak. I plan when the weather gets warm, to flip the rod...to see if that makes it any easier to get in 4wd...It's not hard now, just want to see if it improves it any at all.
Shawn
qukon 95
very very good write up.
i need to go back to the junk yrd and that shifter rod ,is
this rod shorter ? and i took my escy console apart it had
been painted before and very dirty.
I used that same plastic gray primmer and the promoter
spray,sem factory medium gray and clear gloss spray it
should handle scratches good. that bose spk is 2 ohms
so that amp will get hot driving that low impedence.
i need to take a break before i tackle this after dealing
with putting a 2 din touch screen in the truck wife not
happy:gunner:
xanatost
Lafayette, La.
happy:gunner:
she cant be to unhappy. you did sell that alarm you had ;) Oh I did hook it up my self and man that thing is bad as!
qukon 95
Glad you installed it yourself. I might have to get another remote
i dropped it and now the chime is not loud like it was ..but it still
works fine.
95 black i got the 4x4 shifter rod today $1.00 and i think you can
heat the rod up to turn the knob so it don't rub the console i will
turn mine so the angle is pointing at my leg.
I will try to install the center console next week after i put it back
together.
95BlackTahoe
Edinburg, PA
As I recall, that knob has a angled keyway... I don't think heating it is going to help. Mine is really close to the console, but it does not hit.
I saw someone had simply used a smaller metal knob (which I never even thought about) and must have used some glue of some kind to keep it on. Looked pretty good there too. I was on a 92 i think, and it had the regular console, but it would work with ours...
Shawn
---------- Post added at 09:32 AM ---------- Previous post was at 09:31 AM ----------
Oh, as for the Bose sub... Its been 3 weeks now, and it's used eery day, and I have had no issues whatsoever...
Shawn
qukon 95
well.... it's like this the weather was warm fri so i installed
the console and made cuts on the 03 floor shifter cover and
the knob will rub the console a little bit if put in N & 4 L
might have to look into a smaller knob like you seen.
I drilled a hole in the cover to put a green light for the 4x4
indication . I hooked up thet bose sub and man.... that
little sub has some thump with the right LP filter i had it
at 80 hz. The other controls that faces the rear seats i'm
going to cover them holes and where the cd player was
i will make a pocket to make it a usable space and i will
check with a locksmith to see if he can make a key for the lid lock. I will put the pics on photobuc sunday.
qukon 95
heres the eski console painted trim same color as truck
and LEDs in the dash
qukon 95
bad looking console,the bose sub,i put rca's in that rear
piece to hook up the wii game. more pics:Caffeine:
qukon 95
man!! i got spoiled and lucky when i paid $ 15.00 for the
escky console with the sub working i went to local jnk yrd
he wanted $50.00 for the console it didn't have the rear
cup holder nor the top lids and it was dirty and peeling
like they do. all i really want is the sub if it works and
on ebay guy wants $100.00 for the sub damm ! If i get
$50.00 to spare :hmmm2: i might go get it.
Escalade2007
