Annoying Check engine light
Fless
Moderator
People's Republic of Colorado
Once the code sets and it's active, you can connect the scanner and see if there is freeze frame data to go with it. No need to monitor full time. Leave the engine running with the active code and you should be able to see both the code and the freeze frame data, if it's there.
S
SMonaldo
Thanks. The issue that went away for a while after the bank 1 upstream O2 sensor was replaced has now come back, and it went on Friday, Sunday, and again this morning, after going on only twice in 6 weeks prior.
S
SMonaldo
Freeze frame is on this report attached, does anyone see anything obvious jumping out??
  • a4902914-7029-406f-a6af-7f6c254792c9_11092025023719.pdf
scottd
