Air ride Edgy Mods question
CCPLuvr
Today our new AT4 is going in for wheels, tires and Edgy Mods links installed. I've got a question regarding increased ride heights for those that have done this. Will we see an increase of up to 2.5" in the lowered and normal ride height positions? I'm assuming we should measure the vehicle prior to and after installation in the park position, and that should be the same difference we'll see in Normal ride height? Any insight will be helpful. Thanks.
KMeloney
Did you already get your answer since installing the links?
C
CCPLuvr
Yes, but not till after they were installed. I've got to remove them and readjust, they're too low right now.
John from Edgy Mods said to disable the entry position so the suspension is always at Normal ride height prior to installation.
Once I get it corrected I'll post some pics.
Thanks for asking!
PMB 73
Thanks for asking!
Have you installed the Edgy Mod links? What size tire did you go with? Also, how do you like the ride after with the EM links added?
C
CCPLuvr
I didn't keep the overall adjusted link lengths used on my AT4. The ride is a little firmer than stock but it's still smooth driving it.
C
CCPLuvr
Here's a couple links after this was finished:
C
CCPLuvr
The alignment was WAY out after adjusting the ride height. Getting it properly aligned helped the ride as well.
PMB 73
Perfect, thank you for replying. Looks great! I would have to say my biggest concern is how it drives afterwards. Smooth is good! Have you taken it off road or tried to test the air bags?
C
CCPLuvr
I haven't. We don't have anything that'll get pulled behind it.
mq019
Question for you on removing the stock links - how does the pin get removed from the sensor side? Any tips or tricks to help? Seems like it just pops off of the control arm side, but the pin on the sensor side has me spooked.
I've been trying to find video or even a page from the service manual that shows how to remove the pin, and cant find anything (cant even find the service manual).
I have the links, but haven't gotten up underneath yet - I wanna make damn sure that I'm not gonna break the sensor or pin before I start.
C
CCPLuvr
Are you talking about the cotter pin?
I had my local shop that did the new tires/wheels actually install my links initially. They didn't adjust them correctly so I had to finish that part. I have the original links but didn't get to see how they removed them. I would assume remove the cotter pin then pull the link off the ball end of the sensor arm, it probably snaps on and off.
mq019
Yeah - I'm not sure if its a cotter pin, or a different sort of pin. Have heard a few different things and haven't gotten a straight answer on that. Trying to sort it out before I try the install - have been trying to find some photos or video of an install that might provide clarification.
I found a picture somewhere at some point that seemed to indicate a plastic pin that pushes through the connector, but don't know if that was the yukon and what year, and now I cant find that post anymore.
The instructions just say "remove the pin" so not clear if its just a cotter pin, or some other type pin. I know one poster here mentioned that he damaged one of his sensors taking the pin out and I'd like to avoid that!
C
CCPLuvr
Here's photos from one of the OEM links that came off our AT4. The pin is probably this cotter pin. Other than that the links just snap on/off from ball ends attached to the vehicle.
I'd recommend measuring your ride height before so you quantify the change afterwards.
jd08
Jackson, WI
Mine had a plastic pin on the sensor side. I used a small flat screw driver to pry it out a little and then used a needle nose pliers to fully remove it from the link. Once removed you slide the link up on the ball and take it off.
mq019
Thanks guys - these pictures are perfect and exactly what I was looking for.
C
CCPLuvr
Have you installed the new links? Post some before and after photos please.
mq019
I havent done the install yet - I'm hoping to have time to do it soon, and will definitely get pics when I do.
AdrienR
