Air pump kicks off after few seconds
Floridabound
Not familiar with the z55 suspension but noticed my bags are broke and installing new arnotts today on newly purchased 2012 Yukon. When I turn the key on, the compressor kicks off after running for about 5 sec. I disconnected the air line and I feel air coming through the line but it still shuts off. Shouldn’t it run continuously with line off? Just wondering if I should replace pump to?
Welcome to the Forum from NH.
Pics of the truck, please.
The compressor has an automatic shutoff in the case of a leak, so that you do not burn out the compressor (doesn't always work). However, the length of time that the compressor runs during a leak situation is longer than 4-5 seconds (which is normal for a system without a leak).
Do you have a Tech 2 or equivalent bi-directional scanner? If yes, you should be able to test the various functions of the compressor and identify any issues.
I can attest that the first part is normal. Not sure about the second as I don't own a car with rear air anymore.
What part of the Sunshine State are you headed to?
Phatazzcustoms
