Air Lift helper bags
skyhighsami
How much will they help to soften the rear out? I replaced the DJM garbage 5" coils with 5305s and the ***** ass DJM shocks with Bilstein HDs on Friday. It rides better but I was wondering how much the helper bags will help. The problem now is the springs are so much softer that the rear bottoms out alot easier. Could these be the solution?
Max
Mile High
Denver
This is how I prevented mine from bottoming out before I did the free travel mod, the bags would have 3-5psi in them and barely raised the rear.
skyhighsami
skyhighsami
I have done the free travel mod. Maybe her's weighs more? When I swapped interiors I did put down 200 square feet of Second Skin Damplifier Pro and it has a custom fiberglass box for the sub. I will order them tonight along with some spindles.
Max
Mile High
Denver
The XL is quite a bit more weight, definitely do the helper bags I need to install mine with the next coils. I have another method for smoothing the ride out on these trucks I should have something figured out in the next week or so.
Max
Mile High
Denver
Too busy sorting out my nitrous at the moment, but these are what I have planned:
Gonna cut out the center of the frame and run them through if I can, should ride real nice with progressive tension through about 4" of compression.
mfinta
