Aftermarket running boards/nerf steps???
Landonz
Looking for some aftermarket running boards. Preferably the offroad looking style. Its a 13’ Z71 so everything I have seen online says excluding Z71. Im assuming because of all the plastic that goes around the oem running boards…Anyone have any recommendations?
PG01
Up here to the right
I think it’s because the z71 uses the rounded nerf style steps with only 3 mount brackets while the non z71 boards have 4 mount brackets something like thst.. maybe just different brackets … regardless the non z71 mount can be found online ebay or whatever and the mount bracket holes under the truck should be there with either a plug in them or just open threaded holes
Did you check out Westin?
tooleyondeck
Northwest FL
AI says:
"For a 2013 Tahoe, the mounting for running boards is different between Z71 and non-Z71 models due to the Z71's unique rocker panels. Running boards for a standard Tahoe are incompatible with the Z71 package.
Rocker panel differences:
The primary difference is the rocker panel design, which affects how running boards can be attached.
  • Non-Z71 models: Feature a smooth, standard rocker panel to which aftermarket and OEM running boards can be directly mounted.
  • Z71 models: Have a different rocker panel shape with integrated plastic cladding and trim to protect the body during off-roading. This cladding covers the mounting areas for standard running boards.
Mounting location and compatibility:
  • Non-Z71: Running board brackets are typically designed to bolt directly into pre-drilled holes on the vehicle's underside, connecting to the inner rocker panel or frame.
  • Z71: The unique body cladding blocks access to the mounting points used on non-Z71 models. Consequently, Z71-specific running boards are designed with a different bracket and mounting system to accommodate this unique bodywork."
Sounds like you may be able to modify the cladding to expose the non-Z71 mounting points, might be worth it to remove it and verify that they're there.
Sparksalot
Bastrop County, Texas
I put these on mine after an incident with a “rocky stream crossing”.
mikez71
I have installed NON-z71 steps on my z71, so it's no problem with the cladding removed.
...which you will want to do, because the cladding is made to fit the z71 steps.
Coveman
I’m still liking my amp power steps on the ‘13 burb, 5 years now
Dh1280
