Running boards
Randy Baylor
Do the metal Z71 side steps that come factory on 2021 Suburban Z71s have the same bolt pattern as the large plastic/chrome running boards that came factory on my 2021 Suburban Premier?
I assume so, but hoping to get it verified before purchasing.
I’d like to change them out as part of a chrome delete and lift kit…
KMeloney
I have no idea... But maybe you could be a little more descriptive in your post title to get some more eyeballs on it.
All you really need is for someone with a Z71 Sub to look under his truck and maybe snap a pic for you.
GMCChevy
See if you can find pictures of both off, they should be the same or holes there.
all the same, only difference is when the body is short wheel base versus long wheel base.
i.e. can't swap tahoe/suburban running boards
Vladimir2306
Yes, the location of the bolts and the fastening of the thresholds are exactly the same, because the body of the Suburban is made alone, for all configurations. You can easily set the thresholds from Z71 to Prime. I set myself thresholds from stationary to medium configuration on Yukon Denali, instead of electric thresholds.
The only thing that is impossible is to put electric thresholds on a car where they were not originally installed.
R
Randy Baylor
Good advice, new to this!
CRN_25
