Aftermarket head unit installed, rear speakers don't work
99_Yukon
Michigan
So I installed my new head unit and my rear door speakers don't work. The cargo area ones in the roof are still on as are the fronts. Any ideas what I did wrong?
juggjiggler69
Thats funny when i did mine my doors worked and not the cargo ones i had to run new wires to my doors and still havent got to run wire to the cargo ones
Sent from my Galaxy Nexus using Xparent Red Tapatalk 2
99_Yukon
99_Yukon
Michigan
Why did you have to run new wires to the doors?
knoslf
Thornton, CO
Not sure about this but i was told that the factory amp(if u have one) powers the rear door speakers, may need to bypass the amp but like i said, I am not 100% sure, someone told me that.
juggjiggler69
All of my wires in the dash r hooked up and i still had no sound from rear so i just ran new wires i dont even think mine has a pink wire in the dash
the big blue bus
richmond, va
under the drivres seat. its tiny bout size of hand. i ran a wire from the orange plug i think in it to the remote on back of headunit. mine was werid. it would work in tunner mode but not ipod so i run ran a wire to trigger the amp been working fine
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you have to trigger it using the pink wire in dash that activates relay for the amp. if you feed you HU control wire to amp it will not work. At least not without damaging you HU or amp.
99_Yukon
99_Yukon
Michigan
So I can just wire the pink wire for the amp relay to the acc wire to turn it on?
Tahoe_96
love the searrch tool ...ran into this problem and then fixed it 5min later
avatar99
I had this problem once. If you use the power antenna wire from the aftermarket head unit it only will power when in tuner mode. The amp trigger wire has to be used.
RAWVORTEC
Lburg
So i have had an aftermarket pioneer head unit for over 2 years now. My rear speakers have always worked. They just stopped 4 days ago. I went through setting to make sure fade was correct, and all loooks good. I do have a 1kwatt anp and 2 12s. None of which work. Help!
TejasPitt
