Advice on engine replacement
2Cool2Fool
I’ve got a 2016 Yukon with 128k miles. I’m pretty sure I’ve got a collapsed lifter. The problem started with the engine seruosly bogging between 1000-1500 rpm - and within less than 10 miles - it was making a very long tapping sound under the drivers side valve cover any time the rpm’s drop under 1000.
I talked to the local shop, and he said it sounded like DOD lifter. He said that if they confirm that I that as the problem, have two choices: have them do a DOD replacement - or buy a Deleted rebuilt long block. They said that at 128k miles, doing the DOD replacement is almost as expensive in terms of parts and labor as a rebuilt deleted long block.
Anybody have experience with this and the name of one or two reputable long block rebuilder? Thanks
Marky Dissod
... two choices: ... DOD replacement - or buy a Deleted rebuilt long block
Option 2, regardless of whether you replace your engine with a 5.3L, a 6.0L, a 6.2L, or a 6.6L.
You might be pleasantly surprised when you find out how much a 6.0L costs, especially compared to the 5.3L.
Marky Dissod
JamesinAbilene
