Adaptive Cruise Control
Eiran Rodriguez
I have a 2019 Tahoe Premier, when I press to activate the Cruise Control the Adaptive Cruise Control icon displays on the dash. When I try to set the speed I get a message on the dash "Adaptive Cruise Control Temporally Unavailable". The Cruise Control cancel button to the left doesn't turn this off neither does the break (not sure if that's a thing). It's only when I press the Cruise Control button to the right will it turn off. My issue is I want to change from the ACC to just regular Cruise Control but holding the cancel button will not switch it (what the manual said to do). When I bought the Tahoe it was lifted and has a Fab Fours Vengeance Bumper. I'm thinking there might have been an issue reconnecting the radar or sensor when this was replaced. I was unable to find the shop that did the install. Is there an easy work around to this? I tried to be as descriptive as possible. Any insight would be appreciated, thanks in advance.
E
Eiran Rodriguez
Any codes from the module?
Yes, Action Required - Front Radar Blocked - See Owners Manual and Information - Forward Collision System Unavailable. I'd like to add that the sensor that controls the seat vibration still works when I pull up to like the garage.
GMCChevy
Did you look underneath for the sensor? From your description it sounds like maybe that bumper is blocking it.
E
Eiran Rodriguez
I'm not a car guy like that, but that was next on my list and take some pictures of what I'm seeing. Thanks
Loki223
Elk, WA
This thread might be helpful...looks like there are a couple locations for the sensor system, but chances are the aftermarket bumper is blocking the sonar signal and not allowing ACC to work
StronCoreBerlin
I live in Berlin Germany and trying to find out this: It's about a 2016 Escalade. The radar unit was purchased used as a replacement after the original was damaged in an accident. After installation, it obviously needs to be calibrated.
My question: After installation, the unit usually shows nothing when cruise control is activated – in other words, it doesn't work. Is this normal because it hasn't been calibrated yet?
Only occasionally, very rarely, the unit responds and cruise control can be set – but it stops working again after a few minutes.
Is there any chance to get this calibrated by myself?
GS Audio
