Accessory Trailer Camera Reverse Guidelines
gmcnick
Just purchased a new 2025 Yukon Denali with the Denali Reserve/Enhanced Trailering Technology Package. I also purchased the GMC trailer accessory camera. This package is supposed to show guidelines behind the trailer when backing the trailer up in reverse, but I can't seem to activate them. The guidelines show in reverse without the trailer. The accessory camera works/shows what's behind the trailer, but no guide lines. Any ideas on how to activate this? Thanks!
BacDoc
Vero Beach Florida
The camera shows what is behind the trailer? Where does that camera mount?
On the trailer package that comes with the 2024, you have many options for rear view and looking at the trailer but nothing behind the trailer.
In the 360 camera menu you can change the view and change the lines/track/hitch view behind the truck.
To see behind the trailer I would think you would need a camera on the trailer as most trailers would block any cameras mounted on the vehicle.
G
gmcnick
Right. The accessory camera comes with a 60' so you can plug the cable in at the trailer hitch camera port and then install the camera on the rear of the trailer. From the package description: "Provides guidance when backing the trailer to achieve the desired path"
Tupapi
