Page 2 and I'm running out of popcorn. We still don't know if it ever ran good, if the check engine light has come on, if there are any codes set and we don't know what the fuel pressure is.
Found some!!
Hey
@KingMyersJr26 , can you answer Eman's questions? Namely,
Have you gotten a check engine light?
Have you retrieved the codes? Some codes get stored even if there is no check engine light.
What's your fuel pressure with:
a) the key on, not running, and
B) at idle?
If you don't have a gauge or know how to check, say so. I think it should be minimum 60 at idle, a touch higher with key on.
Also,
Have you replaced the fuel filter? I believe it's on the driver side in the frame rail, under the rear doors.
Have you assessed the condition of your fuel lines?
We are trying to help you out...help us help you.
Finally, I'd like to know:
Any recent work on the rear end?
Any recent work on the brakes?
And once the truck does get moving, is it smooth sailing or sluggish?
You can copy and paste the questions to make answering easier.
