AC Cooling in extreme temperatures
RED TAHOE LS
Rossville, Georgia USA
I took these photo's today as you will see outside temp was 88 degrees.
You will notice I use a robinair gauge, normal range of 38 to 42 degrees.
Temperature @ center outlet around 39. This year Tahoe has a clutch fan
without an accessory cooling fan, as the temperature rises the clutch fan engages and roars till
temperature falls. Y
RED TAHOE LS
RED TAHOE LS
You gotta understand these animals are HUGE, a lot of roof to heat the interior. In traffic as the outside gets above 90-95, it will ease up to 41-42 degrees. Once it cools down, I run the front fan on #2.......and the rear fan next to high, works well, doing the front door tint really helped.
GMT800 2005 Tahoe Z71
Navy Supporting Member
Yep. That's why @RED TAHOE LS said that once it cools down, meaning the fan was on high speed to help get the hot air out and then he drops fan to #2 and that will show a lower temp reading than when on high fan speed. Check it with any thermometer. Leave it on high fan and the temp will be higher. Not a huge amount but it will be higher than on the lower fan speed with less turbulence.
temperature falls. YView attachment 348630
My gauge was from O'Reilly's and is usually in the low 40s but sometimes in the 60s. It has some actuators that need changing still. I hope mine still runs as good as yours when she's that age!
97YukonNZ
Looking at your cluster,must be similar year to my Yukon. Doing same temp and oil pressure at that temp too. Nice!
Going to get my front windows tinted at some stage to darken the rears off a bit more.
Miami-Dade
Moderator Supporting Member
That is the reason I run my a/c on the lowest speed 99% of the time....Even in the Miami 24/7 jungle heat. The only time I use the rear a/c is when someone is back there. Otherwise it is not really needed. Of coarse tint all around helps.
j_jerry79
