ABS Light.......
Flyhatch
Pittsburgh, Pa.
I spied the light on this morning. I drove to work and before I left, I shut it off and restarted it, and the light didnt come on agian. When I left work, It came back on agian. :(
What are the most common causes?
What can I do to narrow down the reason the light is on?
The Hoe stops fine.
Thanks for the help.
E.
rucr8z2
Saluda,Va.
usually comes on for a bad speed sensor, go to advance auto have them pull the code-usually for free and find out which sensor has stopped reading....
Chevyrider619
Virginia Beach
Mine's been on (ABS LIGHT),for a month but cause my left front speed sensor was not making good contact..I spliced it abs light went off but,today it acted up..As i was stoping the brake got hard and made a weird noise but it went away..Anyone have an idea it thats cause of the sensor too...
rucr8z2
Saluda,Va.
abs system works by imputing speed from individual wheels to tell the computer which wheel if skidding or not braking enough and then the computer varies brake pressure to individual wheels (pulsation can be felt in pedal) to keep from locking up the brake and skiding out of control.
ravingmadman
Chief Knuckle Buster
Greater Seattle
Where are the sensors for the rear wheels? There are no sensors on the wheels themselves.... Or am I really missing something?
rucr8z2
Saluda,Va.
It uses the speed sensor in the transfercase(4x4) or in the transmission(4x2) for the rear speed signal because of the straight axle. Only some of the newer trucks have them on all 4 wheels. If you lose this signal the ABS light would be on along with the loss of the speedometer.
clean454
so if theres a bad speed sensor the speedo wont work? cuz my speedo works, and i have a abs light on..
rucr8z2
Saluda,Va.
only if the rear speed sensor goes out- Your problem more than likely is one of the front speed sensors.
clean454
hmm alright ill thro a code reader on it and check it out, this mite be the reason why my breaks are wearn weird
rucr8z2
Saluda,Va.
when the dash throws an ABS code the ABS system is shut down and only regular braking system is in effect. so if your brakes are wearin differently from side to side then check for a caliper hanging up or a rubber brake hose bad.
ravingmadman
Greater Seattle
That's good poop. I didn't realize the speedo sensor also ran the ABS. That actually explains some other minor quirks I've been having with my Hoe. I'll post a new thread so as not to thread jack. Thanks again.
veteran111
