docster
My ABS kicks on at low speed stops on my 2001 Denali. I just replaced the front drivers wheel bearing that was making some humming noise. But that didn't fix it. I also have a history code of co265 EBCM relay circuit and CO281 stop lamp switch circuit open or short. Could that be causing the problem? Any suggestions on where to go. I am concerned this may affect the brakes on the Airstream while towing, what do you think?
any and all help much appreciated.
---------- Post added at 08:45 PM ---------- Previous post was at 08:04 PM ----------
ok, I just went out and when the abs kicks on, steering wheel turns left. So im thinking it must be the right front. Should I just start with a new wheel speed sensor there?
