2000tahoeZ71
- Joined
- Jan 13, 2014
- Posts
- 236
- Reaction score
- 2
Alrighty so I replaced my motor back in December of last year, and afterwards my front A/C has not worked properly. It just seems to blow ambient air temperature. I checked the charge with my gauges and it is within normal ranges. The rear air blows ice cold. I checked under the hood at the heater box diverter valve and it was not closed all the way. There was vacuum coming into the solenoid on the firewall, but not leaving it headed to the valve. I checked the plug with a meter when the tempcontrol was on cold and read 0volts. I assume the HVAC control panel is not functioning properly and sending a signal to the solenoid to allow vacuum through and close the valve. For testings sake, I zip tied the valve closed and checked it. Still not cool. Is there a door that diverts between the heater box and the AC box? I have read that it could be a blocked orifice tube in the front. Any ideas????
