A/C issue in Tahoe 2009
Extrovert
Hi Guys,
want share my issue hope that someone can help
A/C blowing hot Air i tried bypass the wire in low pressure switch i turned for a while, now i am not able to let the A/C clutch engage in less wire cable from A/C Relay to the ground then it ll engage tried to recharge it but nothing change i have change both valve low and high pressure plus the sensor
do you think required an oil or compressor is not working
please i need to know how much PSI should charge in this car also any idea how to test the relay
the weather here it's about 50"C or so depend :(
Waiting for prompt support
Extrovert
Extrovert
Hi ,
issue has been solved recharge the Freon but both Fan an low and high still not working
glazar
