ravingmadman
Chief Knuckle Buster
Hey guys. This is my first venture into interior work, and car audio. This is fun. The prior owners butchered the wiring in my truck. Yesterday, the harness went to the front driver's door, and went to some sort of box with 4 speaker connections. No power, nothing else. Possibly a crossover? Doesn't matter. The speaker wires then split at the box and went to the 2 speakers in the front driver's door. I didn't know we had a little tweeter in the armrest!!! This was all broken, and non-functioning anyway.
Last night I removed everything, disconnected the stupid door tweeter, cut all the extra crap wires, added a 4G wire from the battery to the back seat, put a 4G ground in, and ran 18G from each speaker through the door pillars, along the floor under the trim to the back seat. I wound up removing roughly 10lbs of extra wiring bullshizzle from my Hoe. 3 plastic grocery bags full of hacked up wires, splices on splices held together with duct tape and even some blue painter's tape. Busy night.
I removed the old deck and threw it out. I ran 3 stereo RCA's from behind the deck to the back seats to provide signal to the amps. One amp will run the door speakers, one amp will run the sub(s).
I'm trying to install a new deck now, and I'm wondering what the difference is between the dimmer and illumination leads in the harness? Also, what should I hook the remote for the subs up to?
http://www.the12volt.com/installbay/stereodetail/574.html
Gratefully....
Gratefully....
