96 2 Door Yukon
jrawk1120
Southwick, MA
I'll be going under the truck tomorrow, well tonight, to attempt to find an oil leak.
I had the rear main seal replaced about 2 months ago.
Any other common places to check for oil leaks. I've heard oil cooler lines and oil pan gasket.
Any help is appreciated and thanks in advance!
itsagaas
Stewartsville, NJ (Warren County)
JRAWK1120,
How did it go finding the leak? I am on a similar mission looking for a oil leak.
Thanks,
itsagaas
JRAWK1120,
Thanks,
I put UV dye in my crankcase and ran the engine for 5 minutes then shut it off and got under the truck with a blacklight. No missing the glowing oil coming through the oil pan. This is not a gasket leak. There is actually a pinhole in the oil pan itself. I jave the pan off now. Will also replace the axle seals and pinion shaft seal in the front differential as part of this job.
Basecamp
