95 Tahoe - brake lights, left side turn signals
Big_Deddie
OK - revamping a 95 Tahoe for my son. Already rebuilt transmission and now working on the electrical issue.
Neither the front or rear left turn signal works. The right side works, but blinks really fast. There is also no brake lights.
My first inclination was the bulbs in the taillights (before I realized the front wasn't working either).
I would think brake light switch...but that shouldn't effect the turn signals.
Any idea where to start?
PG01
Up here to the right
I would go thru all the bulbs and replace them, check the flasher module in the fuse box and check all grounds. 1 bad bulb can screw up all of them as will a bad ground. The flasher module is suspect also, what happens with the 4ways?
B
Big_Deddie
I don't remember checking the hazard lights as I was already to the point of frustration at that point.
I did replace two of the bulbs as I suspected that the bulbs themselves could be the culprit. No luck.
My wife says that this only happens when the headlights are on - I will verify this tonight.
mfinta
