60/40 rear seat fold down..
ThwopKing
Bunker Hill, WV
Ok I feel like a moron...the rear seats in my 'Hoe are being a pain..how do i fold them down. The owners manual says there should be a lever thats marked "1" to pull down...its not there anywhere. The seat bottom has the strap you pull up to lift but we cant figure out how to fold the seat backs flat..ive looked everywhere and cant figure it out lol.
M.M. 700
Are you talking the second row seats? if so, They do not fold back. The fold forward. Lift the strap on the lower portion of the seat and grab the back of the seat and push forward.
The 3rd row does not fold back either. There is numbered levers on both seats. Pull in order to remove/or pull lever and fold forward.
Boomer73
Boom Boom
Crownsville, MD
If you are talking about the ones with the numbered levers all the way in the back, they are the 50/50 rear split, not the 60/40. 60/40 is the 2nd row bench seat.
For the 60/40 2nd row, do what MM 700 said. For the 50/50 3rd row, folding the seats up follows the #1,#2, #3 lever process but putting the seats down isn't the exact reverse of this so its a little misleading. If your 50/50 seats are already folded up, push the seat toward the front of the vehicle gently while pulling the #3 lever toward you (it rotates down toward the floor). The folded seat/backrest should then rotate down to lock on the rear-most anchor points. You then lift lever #1 to release the backrest and pull the backrest to the upright position.
-B
ThwopKing
ThwopKing
Bunker Hill, WV
Yeah i meant fold foward..and yeah its the 60/40 2nd row bench..i dont thave the 3rd row seat, thankfully! Wow ok so i just force it down...i didnt wanna break anything by strong arming it! lol Ill give it a try in a few mins.
M.M. 700
You shouldn't have to force it. Make sure the bottom portion of the seat is position fully forward. I think there is a release cable on the lower portion, that allows the back part of the seat to fold...
Try both sides, maybe the one side you are messing with is $%^&ed up.
dropmech
Puddle Pirate
Coral Springs
If the seat back doesn't come forward then you have the seat bottom down all the way. There is no magic click or anything like that.
ThwopKing
ThwopKing
Bunker Hill, WV
Yeah i felt like a ****..the seat bottom wasnt folded all the way up because the front seats were to far back. Thanks guys.
GJamil3
Lancaster,Pa
LOL dont feel so bad when I got my 04 Hoe I had the same problem and the book does say look for handle #1, and then all of a sudden on a RAINY DAY WE HAD TO FOLD THEM DOWN AND IT JUST HAPPENED AFTER WE PUT MY DRIVER SEAT UP. sO IF YOUR A MORON THEN i GUESS WE WERE TOO THAT DAY
SoCal03
NEED HELP!
I figured out the part about folding the seat bottom all the way forward, but I did notice a crimp in the cable that is supposed to "actuate" or release the headrest to fold down. It's beyond the point of repair, I know it needs replacing. Is there any bypass or was of getting it to fold down? I've pulled with a set of pliers, but the head rest still won't fold down.
Part 2. How hard is it to remove the rear seat leather (cover, I imagine) to replace the faulty cable?
This should be a recall or something..
Thanks in advance, Chris
blaqout
King Yukon
Indianapolis
LMAO, I just grabbed a 2001 Suburban for a winter truck and could not figure out how to let the seat down for nothing. Thank goodness for this forum, LOL!
wh134802
I have a Solution to the rear seat latch not working
I have a 1997 Tahoe 5.7L 4 Door with the 60/40 rear seating.
The cable which releases the rear seat to drop down broke and the 60 seat would not fold down.
From behind the seat you will see a small opening where the seat meets the floor carpet. Take a flashlight and a flat head screw driver and push on the latch which will release the seat. I used a second driver to wedge the seat up so I could see in there and find the release latch. Then my tool (flat head driver) to push on the release latch.
I tried for about an hour to address the problem from the front looking at the assembly. But then realized I could see the actual latch from the small opening where the bed meets the seat.
Hope this helps someone out there
-W
TejasPitt
