$500.00
qukon 95
There is a 97 Yukon 4wd needs a trans ,1 tailgate hinge broke off on the body(rust),220.000
Miles on it,little rear light issues ,clear coat came off in spots , interior in really good shape
, exhaust leak and a driver side view mirror. For $ 500.00 thoughts
livingez_123
Sandy, OR
trans can run anywhere from $200 for a used to $1,500+ for a quality rebuild. Everything else is nickel and dime stuff, but it does add up. If it suites your needs and you'll be happy, why not. Or you can flip a coin, I've done that before....more than once!
God
Or you can buy it for a spare parts vehicle
Worst case scenario easily turn a profit on that $500 and/or use it for parts
Gzes
the drifting 2dr
Wichita tx
I would use it as a donor. Get it then get one needing parts with good body. Sell what you don't need
qukon 95
qukon 95
If I do get it I won't use it for a donor fix it to drive or sell. Good thing I can do all the work to it
Just need time & money
inthechateau
Maryland
I just bought a 97 with 195K on it for $400 with out tranny. Need the rear, brake module, and a bunch of other little stuff. Good body and doors though. May part the rest of it out. Trying to get the guy to shoot me a pic of the rpo codes now. You can never have too many spares if you are going to keep one of these OBS trucks on the road. Engine on this one runs but it has a knock. Might just drop my spare crank kit into it and flip it too.
qukon 95
qukon 95
What's the code for a problem with trans I no this truck had a trouble code for the trans.
xanatost
Lafayette, La.
I rebuilt my trany and its a lot easier than rebuilding a motor. You will need only one specialty tool. I like these guys because there service is second to none and the money I saved I built mine to a stage two. All the parts and tool ran me around 500 bucks. I took a few months reading up on my transmission and find the weak points and after I got all the parts I dropped the trany at 8am and had her back on the road by 6pm testing everything out. Mine is 4x4 and I do a lot of expedition rides and so far after 4 years of wheeling her I never had a single problem out of my transmission. Get the DVD and it will walk you through on how to rebuild it and give you some good tips as well. If you go that route give a yell and Ill give you a hand with it. Owe you for helping me out with my new alarm :)
Oh where are you located at?? I might need a good excuse for a expedition trip ;)
qukon 95
qukon 95
You got it all wired up with the door locks working with the relays I gave you ?
qukon 95
qukon 95
Well didn't have the funds to get it but I did get the skid plates.
JeffK
