383 Installed
turk
Finally got my '99 back today. I had a 383 GM performance engine installed. I picked it up and I can definitely tell it has more power, but I know there are more ponies there that I am not able to spur. I am currently in "break-in" mode as well.
Couple questions:
Anyone else on here do this swap? If so, are there any quick fixes to increase the horsepower. I didn't know if a programer would help. I am running stock gears, stock intake, and stock exhaust.
Should I have it Dyno Tuned?
ezdaar
Chat Troll
Redneck central, Aka Houston
ofcourse theres power to be made.
Full exhaust, LT to tips.
CAI.
Full roller rockers.
Higher stall converter.
Under drive pulleys.
Obviously a full tune.
Etc...
Just decide what your budget is and go from there.
bowtiefreak
No Quarter
Near Philly
a dyno tune. Been through all this with my 383. a custom, dyno tune is really the only way to go
turk
turk
Would you consider the Black Bear tune a custom tune?
I don't know of anyone around that has a dyno... I'm sure there are some close... I live pretty close to Joplin, Mo....and then finding someone who knows what they are doing is another thing.
bowtiefreak
No Quarter
Near Philly
Black bear is but a mail order isn't going to cut it. if he did it in person that is a better option. A dyno being the best option
turk
turk
Thanks guys... found a guy within 45 minutes that custom tunes and comes highly recommended.... will let you know how it turns out.
KPOD
Michigan
Make sure to get all the bolt ons you want installed before you take it to get a tune, saves money from having to be retuned again :p
turk
turk
That was my next question... thanks.
I was thinking of changing my exhaust next year... probably should wait on the tune until I do that?
I was also thinking of changing my gear ratio and I'd like to wait on that due to $$$... that should not affect the tune, should it?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the pcm needs to be programmed to know it has a 383 so as to get more from it. blackbear should be able to take care of that easily.
bowtiefreak
No Quarter
Near Philly
I can vouch the difference is amazing. My tahoe with a 383 is so much more motor than the suburban with a 350. Both are set up very close other than motors...and some obvious weight differences
BlacktopBandit76
