305/45/22 will fit nicely!
Dogged
Just installed a set of Nitto Ridge Grapplers on the stock 22 wheels. Looks so much better. No rubbing at full lock. I don't think it will hit the liner ( but it's within 1/2 inch) with suspension travel. I'll update as I put some miles on it. So far great ride and no road noise.
olyelr
Elk Rapids, MI
Hell yea looks great!
They definitely made a bit more room in the wheel wells.
debo4x4
Looks great! I'm having 285/50/22 Toyo AT3 put on my Denali this weekend. Was concerned about the width as there's not much room between the top of the A-arm and the inside of the tire, but if you don't have issues then I shouldn't as mine are a little more narrow. If the 33.4 height is too much then I will back down to the same size as you.
DWSmoot
Charleston, SC
I'm running 285/50r22 Nitto Ridge Grapplers (33.5") with no issue. You should be fine. I do have a 1" front level but had no issue before I added the level.
debo4x4
That's good to hear. I was torn between the 305/45 and the 285/50 because of the weight difference so hopefully I don't regret it. I don't plan to ever level either but don't want any rubbing so I'm anxious to see how it turns out.
lasallen
Please post a few pics after this installation if you dont mind
debo4x4
285/50/22
Had very slight rub on inner rear fender well at normal ride height so I did have to zip tie it back just a bit. There's a bracket that the fender liner attaches to that I was able to remove and that gave me the room to pull the liner back and tie it off. You can't even tell it's there unless you're underneath so looks fine.
lasallen
285/50/22
Any road noise with the at 3's??
Dogged
Dogged
I forgot I never reported back... Zero rub issues with stock ride height. Easy upgrade and really make a visual upgrade over those stock tires. Extra width helps protect those wheels from the wife driving
AllyNJ
